moline vapor sytem
ekim
ekim Member Posts: 3
Can anyone explain to me how the "air trap / vacuum valve" should work on this system? dan does not get into much detail about this in his book. the one on this system does not seem to work. i have replaced the boiler. the system short cycles and takes a long time to heat up unless i open the hand valve on top of the " air trap / vacuum valve". then it heats up quickly with no short cycling. the problem is after about an hour steam starts to come out of the open valve. i am considering leaving the valve open and installing a hoffman #75. any help is greatly appreciated. Thanks Mike
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    moline publication in Heating Help library
    See if this is of any help to you.  http://www.heatinghelp.com/files/articles/1375/27.pdf
    Dave in Quad Cities, America
    http://grandviewdavenport.com
