Carrier 3.5 ton 10 seer coil leaking
MosesHomes
Member Posts: 7
Can someone give me the best fix to a leaking coil om my 2000 3.5 ton Carrier 10 seer air handler. I just start leaking out freeon from the coil and the handler works great. where is a good stop in Orlando or on line to get a good used coil for my unit or even a new one. Heat pump system
