What would I include in a yearly maintenance checklist?
Joseph_4
Member Posts: 271
What would you do to service a gas steam boiler, aside from checking the low water cut off?
Boiler maintenance
Joseph, I would start out by going to the manufactures website and looking up the mauual for your boiler. There will be a section on maintenance that will advise you of what you can do and what you should hire. One of the most important is to make sure its burning and drafting correctly.0 -
Yearly Maintenance
Here is a much more thorough answer for you.
http://www.heatinghelp.com/forum-thread/132548/On-Boiler-Maintenance-for-Steam0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
