ticking
MelroseDave
Member Posts: 10
I have a radiator that ticks alot (I have single pipe system), probably more than all other radiators I have combined.
The areas where the radiator comes in contact with the house/floors are clear. It sounds like the ticking is actually coming from within the radiator. Is that possible? Is there anything that can be done to fix?
The ticking is only bad when radiator heats...really nothing when it cools.
ticking rad
it may be the air vent. can you switch vents with another radiator? some air vents are out of kilter, out of the box.--nbc0 -
Slippery Plastic
It still might be the radiator moving across the floor as it expands and contracts. You could try to slip four pieces of slippery plastic cut from a milk jug under the feet of the radiator. It worked for me. (I've also used Delrin guitar picks.) I have also used self-adhesive felt discs made for furniture legs. I've put two of them under the legs opposite the inlet valve. They not only solve the expansion noise, they tilt the radiator a little.
Just my $.02.0 -
thanks
Good ideas. I'll try...The plastic won't melt will it??0 -
The Melting Point of Milk Bottles
Hi - Plastic milk bottles are made from HDPE (High Density Polyethylene) which has a melting point of 266 F and is considered serviceable for temperatures up to 230 F. Since your radiator shouldn't be more than 213 F and probably a lot less where the foot of the radiator meets the floor, melting isn't a concern.
- Rod0 -
Ticking rads
In my last home I had a substantial one pipe system (30+ rads). In our master bedroom, we had the same ticking problem. We tried everything, replacing the valves, pitch, tightening the threaded connecting rod, etc. Nothing worked. The ticking was loud enough to wake us up every morning when the heat came up. None of the other rads in the house had this issue. The only way I could finally cure it was to replace them with two new radiators. After that-quiet as could be.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
