Boiler noise
katbud
Member Posts: 1
How can I correct a boiling type noise which has developed in a 25 year old well maintained oil-fired steel New Yorker residential 107000, BTU boiler? Water is clean and appears to be of good quality wellwater. Also, I ventured a TSP cleaning anyway but with no result. On the one hand I'm suspicious of a mineral layer in the bottom of the boiler because it is only noisey while firing------yet, on the other, I strongly doubt that. Should I attempt to de-lime??---will welcome any suggestions. Thanks.
- 114 Geothermal
