Where to pipe outside wood boiler
Rich Davis_2
Member Posts: 121
As I've been sketching my piping layout for my TT solo 60, I thought someday I might like to install an outside wood boiler. I know I'll need an HE but where do I actually install the piping to the existing piping that I will be installing now, so I can put in the necessary T's and valves that will be capped off. Also are there any critical distances that I should be aware of for my primary piping, I'll be using Taco 4900 air sep and either closely spaced T's or hydro-sep, is there anywhere else that I should consider the distance. Also on the secondary side I was planning on putting the ZV about 6-8 in apart, sound OK. Thanks
schematics
John Siegenthaler has detailed wood boiler piping in his book, Modern Hydronic Heating. A dump zone and/or a buffer tank is usually required to prevent overheating of the system.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
