cap for steam....
kcopp
Member Posts: 4,433
How do you cap a 2" steel steam line w/o the use of a threaded cap? got 2 " line that is out of shape and the die won't fit on..... ty,kpc
capping distorted pipe
can you find some way to put in an internal plug [wood, rubber, plastic]? then drill the end to secure the plug with a bolt. alternatively, maybe there is a rubber cap for vent stacks in that size, which is secured by a screw clamp.
cranking down the pressure to a few ounces would be very important to prevent the plug from being fired out, a la potato cannon!--nbc0 -
maybe...
theytry fire rated expanding foam. you can secure it with sticks of plumbers epoxy, the kind that hardens like steel. although I'm not sure what effects stream has on expanding foam. you wouldn't want it to dissolve into your boiler. does a soda can fit inside thee pipe?1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
plug?
plugging it with something sounds kinda ghetto. If you aint gonna run new threads on the pipe, weld it.There was an error rendering this rich post.
McMaster Sells An Expansion Plug
McMaster-Carr sells an expansion "Test" plug for 2" pipe. It's rated for 225 degrees. I attached a pdf of the catalog page. I'm not sure how long it would last.
2554K75
Bolt-Tight High-Pressure Test Plug for Pipe ID 1.73" to 2.07"
In stock at $33.64 Each
If it were mine, I'd get a weld-on cap.0 -
Shorten the pipe and rethread.
If there is room, cut the pipe back and rethread?0 -
I would but....
There is only 3" to work w/... and that is partially out of wack. The bolt on type would probabaly work....ty0 -
Remove the pipe stub.
The temp caps are just that and I know of none rated for steam. Take it out as you would a radiator spud from the fitting it is in and use a pipe plug.Cost is what you spend , value is what you get.
cell # 413-841-6726
As Charlie says...
... the only way is the right way. Cut the nipple out with a Sawzall, cutting a slot or two in it internally to loosen and insert a plug.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
