super
julio
Member Posts: 1
i have a electric water heater model HV-105 from 1978, with two single switches on top of the boiler and next to the switches is the thermostat.
the one on the left has a reset botton, and the next one is the high limit and last one to the right the thermostat.
i guess the one on the left is the low limit because the next has a label of high limit, how i should set up these single switches, right now i have the left switch on 150 and the high limit on 100, and the thermostat running at 70 degrees F.
