Thermostat for a 4 zone hot water heat
Isnt_it_hydronic_dont_you_think
Member Posts: 1
I have a oil fired hot water boiler for my hydronic heating system. There are four seperate thermostats for each zone. I was wondering is there a programable thermostat I could use to to replace the simple dial thermostats I currently have. Also is there one that I can get to controll all four zones from one location, I am thinking of one that gets a signal from the 4 zones and I am able to adjust all four seperatly from the one controller.
that would be pricey
but you could do digital thermostats with remote sensors, and mount the thermostats in the same area... Tekmar 542s with remote sensors would be our choice.
that's not cheap either but it's probably cheaper than any fully integrated situation.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
