oil burner nozzle drip
carbro
Member Posts: 3
in Oil Heating
oil burner nozzle dripI have a Wayne model MS-R burner (circa 1987). The nozzle is a Hago 1.1 gph, 80 degree cone with hollow spray pattern.
After replacing the oil filter and nozzle for the coming heating season I noticed the following:
About 10 seconds after the burn has ended a few drops of oil drip from the nozzle. I don't recall this happening in the past.
I tried replacing the nozzle with a Delavan nozzle with a protek check valve but the same drip occurs.
The nozzle adapter is a anti drip type and appears to be OK.
After a few drops come out the dripping stops.
I read that air in the oil can cause this problem. Can air get in a fitting that appears to be tight (no oil seeping around threds)?
Any suggestions? Thanks
oil pump?
the cut-out on the oil pump may be starting to fail0
- 125 Chimneys & Flues
- 19 Recall Announcements
