running pex for baseboards
rich67
rich67 Member Posts: 21
I replaced some of my baseboard hot water radiant heaters in my house with new and am running barrier 3/4 pex to supply them. Is there a trick to get the pipe to lay out nice and easy? I seem to be having difficulties getting it to run straight without it bending and curling all over the place. How can I make the turns thru the subfloor to the baseboards without stressing the connection? Pex doesn't bend as easy as I thought.
Thanks in advance for your advice.
