myson B34-1 towel warmer
Steve_210
Steve_210 Member Posts: 664
we are doing a townhouse using a budarus GB162-80 with WM indirect.
the architect wants to add a towel warmer (myson B34-1). he suggests taking it off the domestic hot water recirculation, which concerns me. He forwarded me installation instructions and Myson do show a diagram comming off the domestic recirculation with monoflo tees.
Questions; The Buderus only run's the recirculating pump for 3 minutes every hour - would this keep it warm enough? (We do have other heat, it is only to keep the towels warm).
2) Does the Myson have any corrosive material? (concerned about rotting towel rail or dirty hot water).
3) I could always use an aquastat on the DHWR to keep the towel rail warm. I just would like to know if many people have done this. I could also come off the heating water supply and return to the indirect but it would be alot more work.
  • Steve_210
    another concern
    (off the domestic)
    if someone turned off the towl rail for say 1 month. when its turned on again the stanagant water would be used for showers!!!!!
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    Open system for TBW
    The TBW will corrode on an open system.
  • Steve_210
    brass
    even if its all brass
  • Steve_210
    myson
    myson say its ok but we have never done it before.
  • kcopp
    kcopp Member Posts: 4,682
    what does ....
    your gut say?  If it does not seem right to you don't do it. Just because a Mfg. says it OK does not mean it is so....lots of examples of that.  You are the one who is sticking your neck out. if the architect wants to sight off on it get it in writing... kpc
  • Steve_210
    yes but
    i was to find out if anybody has done this
  • Steve_210
    anyone
    has anybody done an install like this
  • crash2009
    crash2009 Member Posts: 1,478
    Towel warmer
    My place came with a towel warmer.  I got a walk out basement.
