Venting Efficient Oil Boilers
mik
Member Posts: 4
I'm a homeowner concerned about venting and am considering two types of efficient oil boilers, the V. Vitola VB2-33 ( AFUE = 87.2 %) and the Slant / Fin Eutectic EC - 14B (AFUE = 86 %). I understand that both boilers condense and I'm concerned that the 6" flexible stainless steel chimney liner may not hold up. The 100-yr-old house is a two story with an inside chimney, and the flue pipe makes two 90 degree angles before it enters the chimney. The heat loss is about 91 000 BTU's. Can I run these boilers safely with the existing chimney liner? Or should I insulate the flue pipe, consider an double-walled chimney liner (the existing liner is new) or look at boilers that are less likely to condense? I welcome all suggestions.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
