Hot water heater as buffer tank
Roland_18
Roland_18 Member Posts: 147
Hi All,
 If an electric hot water heater is used as a buffer tank, does one need to keep the anode rod in place? If so, why?
Thanks, Roland
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,866
    In a true "closed loop" environment with good air elimination and no substantial make up...
    No.
    Steel requires the presence of oxygen in order to oxidize. Magnesium is the lesser of the two metals and it dissolves in the presence of oxygen first, protecting the unprotected portions of exposed steel tank. Without oxygen, oxidation is minimal.
    So, no, they are not necessary as long as you meet the criteria for a true closed loop system. Don't forget, non oxygen barrier tube makes it an open system...
    ME
  • Roland_18
    buffer tank
    Thanks Mark.
  • Brad White
    Brad White Member Posts: 2,399
    I agree with Mark
    (especially when he is right! :)
    I would only add, I see no harm in leaving the cathodic protection in place, even if a closed system.
    -Ernie White, my Dad
