steam question -renovation
KenOC1
Member Posts: 1
Hi, I have looked at Heatinghelp for years but never wrote in. I am about to renovate the master bedroom in my house which has free standing cast iron radiators now. Both are 25" tall and both are 5 tubes(1- 16 section & 1 -18 section). the Room measures 16' x 16' x 8' high. I want to switch to Gov-Ray type recessed cast iron rads to free up the floor space. By my calcs, I have too many btu's as is. Room has three exterior insulated walls, two double glazed windows, insulated ceiling and no north facing ext. walls. Does anyone know if I can eliminate 1 existing rad and install only 1 recessed unit?
Thanks,
Thanks,
Not with out looking at the whole system
also remember this will need to be insulated between the radiator and the outdoors or it will draw a lot of extra BTU's to warm the room. reducing the heat in one room without changing the other rooms can throw off the balance of the whole system.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 120 Geothermal
