Is a BFP required on my steam fill line if no autofill?
Joseph_4
Member Posts: 319
Can anyone tell me the answer to a question. If someone has decided against an automatic fill on their new steam boiler and will have a manual fill that is opened and closed each time he fills system (say a 1/2 ball valve) is he required to have a BFP (say a watts 9d)? Wouldn't it be superfluous?
Joe
Joe
Not required here
Like you said,would serve no purpose.0 -
requirements for backflow preventer
i could not agree more on the lack of need for a back-flow on a manual fill system; however here in omaha, we were still required to have one installed, and to have the yearly inspection! this in spite of the presence of a spring-loaded fill valve, which cannot be left open.
this device on a steam system, serves only one higher purpose--to enrich the manufacturer! on hot water systems, the situation is a little different.
our option at the time was to use a hose to fill the boiler through one of the riser tappings, with no permanent connection.--nbc0 -
Yes...
in New Jersey at least, and I think for the IRC in general.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
