Graphical Load Estimating Method
Therm_lag
Member Posts: 30
Metered utility use can point to the likely required capacity of heating equipment. A method is shown on attachment. Comments are invited.
Can you
re-post the attachment?
I am surmising this is a data logging function compared to actual degree days, which is something we use to corroborate other calculations. But if the utility is doing this through their metering methods, if you can wait for a year or two under the keel, why not?
Sounds intriguing and if scaled down to a utility service, it could be a fantastic way to have homeowners benchmark their heating costs and see when they drift off-course."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
