Too much water
jdubya
jdubya Member Posts: 1
The other day, I accidentally overfilled my boiler. I drained it down but now it won't work. What's the problem?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    overfilling problem
    there is probably a reset button on your pressuretrol whose purpose is to shut off the boiler when the maximum pressure has been exceeded. this forces the owner to have a look and see if everything is OK. probably, the over-filling causes the pressure, from the water column, to rise above the set-point, and needs to be reset.
    at least that is where i would look first.--nbc
