1-pipe radiator EDR vs. Condensate Pipe Capacity
jpf321
Member Posts: 1,568
Does someone have a chart or table handy of EDR vs. Condensate capacity for radiator supply inlet on a 1-pipe system?
For example, a 1-1/4" pipe can handle the condensate for a 40sq ft EDR 1-pipe rad. (I'm just making this up as an example.)
Thanks.
Thanks.
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
Burnham Heating Helper
Hi JPF- Try the Burnham Heating Helper http://www.usboiler.burnham.com/PDF/htghelper.pdf It probably has a table where you can find the info you're looking for
- Rod0 -
perfect .. thanks Rod!
Here it is from page 3 of the above doc which Rod linked to....
my NEW system pics | my OLD system pics0
