hot air furnace / heat exchanger repair flange????
heatmiser
Member Posts: 16
was recently servicing a hot air furnace the stainless steel pipe that attaches to the flue pipe (this pipe is also welded to the heat exchanger) has holes rotted in it causing it to suck exhaust into the fan area and into the ductwork. is there a clamp on repair for this like two large clamps with metal to seal this area without repacing the heat exchanger
no.
Can you imagine the liability?
Time for new HX or furnasty.0
