Frame house covered with stucco - wall R value
Vad
Vad Member Posts: 55
Hello,
Stucco siding was done couple of years ago to cover frame house. Stucco has about 1'' foam in it. I do not know if there is any insulation at the house's walls. I do not know exactly what kind (make) of stucco it is as well.
  For Heat Loss calculation, Is it safe to count combine wall R value (together with stucco) equal to 10? As I understand stucco alone with 1'' foam can be about R4
Thank you,
Vad
