Vaughn Indirect 50 gallon water heater leaking
We have a 7 year old indirect water heater that is starting to have water pooling around the bottom and there seems to be water leaking (very slowly) from the copper fittings. Is this brand of product worth the money to replace or do people have a better suggestion.
  • kcopp
    kcopp Member Posts: 4,685
    If you are the original ....
    purchaser still under warranty.. Why not. They are OK. They have had a bunch of revisions but I think they have it right. Does it keep up w/. your needs?
    The coil was the main issue which they will replace. Ask your plumber to run the serial #.
    kpc
