Beaver Pipe threader
Dan M_6
Member Posts: 9
I was looking at buying a threader to do larger piping and found a Beaver 41E. I was wondering if it has adjustable dies or if it requires different dies for different sizes and if dies are still avalable? I was looking for a ridgid 141 but no luck. I bought a ridgid 4pj but realized that i needed to buy several dies and was a poor purchase. I cant find any info on the beaver but figured somebody here could give me some info. Thanks Dan
several dies needed
they use a separate head for each size. Parts no longer made for them except custom made. Try craigslist or ebay. Northern hydraulics has a Chinese made threader for cheap that will go to 4". You get what you pay for though. I vote for the rigid.Cost is what you spend , value is what you get.
cell # 413-841-6726
Ridgid 141
If you're in the SF Bay Area, I'll rent you mine. I bought it at an auction 20 years ago and have used it only a handful of times. A life saver when you need it.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 120 Geothermal
- 394 Solar
