Automatic Air Vents
ChasMan
Member Posts: 474
My Smart 50 was installed using the automatic air vent that came with it and after about 2 1/2 years it has developed a leak. For now, I just closed the little cap. I tried to clear it by pushing down on the valve a couple of times but its still weeping so I think I need a new one.
Do I even need this thing? It seems to help whenever I have to drain the system but this zone never needs to be drained. There is allready a big spirovent on the supply line (pumping away).
Is there a better way to go? The Smart 50 has a 1/2" NPT Nipple and then a reducer to a 1/8" NPT thread for the vent. Could I stick a spirovent on a brass coupling or something and forget about it for 15 years? Or, do I have to keep replacing this thing.
couple options...
Ya you really do need it. Yoiu could do a spirotop that spirovent makes. not cheap $45.00. or you could install one of those hyvent shutoffs into the bushing and it would be easier to replace....kpc0 -
Kevin is right
You definitley want a working air vent on top of a Smart tank .
I'm sure there's a purge valve for the indirect . But even after a good purge there's still a ton of air that will get trapped at the top of the tank ( if the air vent isn't working ) .
If you decide to replace the air vent you might want to thread on a hand valve first . Will make changing the vent a snap in the future .0 -
Thanks!
It seems to have stopped leaking. I guess my little flush did work after all. I just hooked in a Runtal basboard heater and there may have been some globs of pipe dope or something in they system that wound up in there. I will order a spirotop and fit it next time I feel compelled to open it up for something.0
