Gallon per EDR question...
Mark Eatherton
Member Posts: 5,875
Is anyone aware of a chart that shows how many gallons of water are contained within a typical cast iron radiator per EDR square foot?
I am trying to help my friends in Breitenbush with an estimate of water volume for the purpose of sizing an expansion tank system.
Gratzi, and Happy Labor Day weekend. Am getting ready for 100 or so of my and my wifes friends to come over tomorrow for the annual get together..
ME
ME
Do you have...
...the chart for balancing a steam system with air vents? They have the multiplier to figure out the air in a radiator. Should be the same to find water volume.0 -
Some formulas
Mark,
I couldn't find anything in the EDR book , I'll continue to look.
Ft./Lb.
Energy
1 HP 0.746 KW 746 Watts 2,545 BTU/h 1.0 kVA
1 KW 1,000 Watts 3,413 BTU/h 1.341 HP
1 Watt 3.413 BTU/h
1 Ton Ac 12,000 BTU/h Cooling 15,000 BTU/h Heat
Rejection
1 BTU/h 1 BTU per hour
1 BHP 34,500 BTU/h (33,472 BTU/h) 34.5 Lb.
Steam per hour 34.5 Lb. H2O/Hr. 0.069 GPM 4.14
GPH 140 EDR (Sq. Ft. of Equivalent Radiation)
1 Therm 100,000 BTU/h
1 MBH 1,000 BTU/h
1 Lb. Stm./Hr. 0.002 GPM
1 GPM 500 Lbs. Steam per hour
EDR Equivalent Direct Radiation
1 EDR 0.000496 GPM 0.25 Lbs. Steam
Condensate per hour
1000 EDR 0.496 GPM
1 EDR Hot Water 150 BTU/h
1 EDR Steam 240 BTU/h
1 EDR 240 BTU/h (Up to 1,000 Ft. Above Sea Level)
1 EDR 230 BTU/h (1,000 Ft–3,000 Ft. Above
Sea Level)
USEFUL HVAC CONVERSION MEASURES (cont.)
1 EDR 223 BTU/h (3,000 Ft.–5,000 Ft. Above Sea Level)
1 EDR 216 BTU/h (5,000 Ft.–7,000 Ft. Above Sea Level)
1 EDR 209 BTU/h (7,000 Ft.–10,000 Ft. Above Sea
Level)
Flow
1 mgd (million gal. per day) 1.547 Cu. Ft./Sec.
694.4 GPM
1 Cu.Ft/Min. 62.43 Lbs. H2O/Min. 448.8 Gal. per
hour
Metric Conversions
KJ/Hr BTU/h 1.055
CMM CFM 0.02832
LPM GPM 3.785
KJ/Lb. BTU/lb. 2.326
Meters Feet 0.3048
Sq. Meters Sq.0 -
Gpm=btu/500
Mark: if we Take GPM = BTU/HR
500 (water) X temp diff deg F
So if we take 150 as the average BTU /ft. EDR at 170 degree water say we have 17 ft EDR. 17X150= 2550/500= 5.1 gal It sounds like it might be close. That is the amount of water needed for that many BUT's. ?????0 -
Found it!
Mark:
Burnham's heating helper page 50. I tried to copy paste but the columns when all over.
I tried to doctor up the water content column.
MC
A. RADIATION
Based on Sq. Ft. Rating Water Content/Gal. Weight/Lbs.
Slenderized Radiators 0.066 4.5
Large Tube Radiators 0.103
Column Radiators 0.188
Convectors (Non-Ferrous) 0.004
Convectors (Cast Iron) 0.040
Radiant Radiators 0.066
Base-Ray (Cast Iron Baseboard) 0.066
0.066
0.103
0.188
0.004
0.040
0.066
0.066
4.5
5.25
7.0
1.5
3.4
5.0
4.4
B. STEEL AND WROUGHT IRON PIPE (STD. WGT.)
Nominal Size:
Inches
Based On Lineal Foot
1/2"
3/4"
1"
1-1/4"
1-1/2"
2"
2-1/2"
3"
4"
5"
6"
.016
.028
.045
.078
.106
.174
.249
.384
.661
1.039
1.501
.132
.231
.375
.648
.883
1.455
2.076
3.205
5.519
8.662
12.510
C. COPPER TUBING (TYPE L)
Nominal Size:
Inches
Based on Lineal Foot
3/8"
1/2"
5/8"
3/4"
1"
1-1/4"
1-1/2"
2"
.007
.012
.018
.025
.043
.065
.092
.161
.063
.101
.151
.210
.357
.544
.770
1.340
D. WATER CONVERSION FACTORS
Lbs. of0 -
Thanks Mark...
and to the other posters as well. SHould be able to get them into the ball park.
ME0
- 114 Geothermal
