Floor Sensors for Raupanel
tpalmer
Member Posts: 1
I'm getting ready to do my first radiant job using raupanel and was wondering how you would implement a floor sensor with it. The only way I can figure is using a router, cut a groove in the 2" filler strips, then silicone the floor sensor into the groove. Does this sound good to you guys? Has anybody else used a different method? Thanks for your help.
slab sensor
here is a tekmar slab sensor manual, there is some good info & diagrams in it.
http://www.tekmarcontrols.com/literature/acrobat/d079.pdf0
