radiator placement
IZZY
IZZY Member Posts: 59
I'm adding a new room to my house above the attached garage.  The room will have 2 1/2 exposed walls.  As of now I'm going with cast iron radiators in order to match the rest of the house.  I know they are usually located below windows, not sure why...does it matter?  Looking for suggestions for placement of radiator/s.  Thanks.
  • kcopp
    kcopp Member Posts: 4,685
    they are usually...
    under windows because that is where the most heatloss is. That being said if you cant get them there or it is impractical.... as long as they are evenly placed  that will work out fine.
  • IZZY
    thanks
    thank you.
