Aquastat
MP1013
Member Posts: 17
Where is the correct placement of a Maual Aquastat in a Hot Water Boiler
Where the
Manufacturer tells you is the simple answer. Most go in a tap on the front top corner. some go in the back if it has a tankless coil it goes in that plate.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 120 Geothermal
