Lost address
Charlie from wmass
Member Posts: 4,422
I had a company that would make push nipples for radiators and I can not find the address. Anyone have one I tried a wall search but missed finding it. I thought it was a company called Onieda. Thanks guys.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
cell # 413-841-6726
It's in this article
Oneida County Boiler Works.
http://www.heatinghelp.com/article/11/Hot-Tech-Tips/137/An-old-radiator-Q-AAll Steamed Up, Inc.
Consulting0 -
I found a radiator with two taps on one end both at the bottom for gravity hot water. I will be seeing if I can salvage it as the previous owner tried to fix it themselves. No they were not experienced in radiator repair.Cost is what you spend , value is what you get.
cell # 413-841-6726
What make and model
is it?All Steamed Up, Inc.
Consulting0 -
I have no idea
It is very ornate but I have not found a marking for the manufacturer. I will get photos posted. The whole house was piped with both feed and return on the same end of the radiators.Cost is what you spend , value is what you get.
cell # 413-841-6726
