Pex run inside 1 and 1/4 iron
Coffem
Coffem Member Posts: 2
Here's one for you...
Second floor conversion from steam to hot water. Currently, or, previously there was single pipe steam run from basement boiler to second and third floor.
The challenge of course is always getting the piping up there. We have an idea to snake 1/2 inch pex (times two for feed & return) inside the existing single pipe and then connecting the pex to rad as supply/return. So far seems like the two pex will fit, but worry a bit about the abrasiveness inside the old iron.
Bet this is unique, ideas???
