Need to move some cast iron radiators
H2Oradiators
H2Oradiators Member Posts: 10
Quickly...I found this forum while researching how to disconnect and relocate some old radiators in my new (to me) home. Looks like a lot of great information, which is a good thing, since I am a serious rookie in this department.
anyway, the system as far as I can tell.
-originally steam, based on the size of the pipes in the basement.
-two pipe system, for feed and return.
-two year old boiler.
-all piping is exposed between floors
-house is balloon framed,2 1/12 story, built around 1910.
-the current heating set up looks to be at least the third that this house has used.
I need to disconnect two of the radiators immediately so that I can get at the walls behind them for the renovation that I am doing. Once that is done, I intend to relocate them, in the same rooms, but to more advantageous locations. This will involve no new plumbing from the basement, but will require adding/subtracting as much as 36" of horizontal pipe length, depending on the room.
If I could find a heating contractor who would take the job, I would. Since I can't I am looking for tips and experienced opinion on the best way to go about this.
    Steamhead Member Posts: 18,534
    Where are you located?
    We might know of someone who could handle this for you. Have you tried the Find a Professional page of this site?
    Consulting
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,425
    large pipes do not always mean steam
    Gravity hot water systems actually used larger pipes than the steam systems of the same era. Check the find a pro before giving up on a contractor. Some of us will travel a fair distance when it can be worked into our schedules.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
