fan control
eric_40
eric_40 Member Posts: 4
I'm working on a williamson air handler with electric heat I cant seem to find the part. The condensing unit comes on but the indoor fan doesn't come on.This is a 220v unit. I have 110 v coming to the unit at the L2 and no voltage at the high speed wire on the motor. I have power going to the fan control but not coming out.. the fan control is a Robertshaw, TDS 3-L    C86210   The air handler Model # is 7324-25-2006   sreial # A8106519. i'm sure the control is bad and its been a while since i've worked on one of these (or anything for that matter.) I can't seem to find the part . thanks
