INSULATION FOR UNDER RADIANT
Paul_11
Member Posts: 210
I want to install 1/2" or 3/4" insulation on a radiant job so the heat goes up into the room and not down to the floor below.
It will be over 3/4" plywood (glueboard) on the second and third floors of a residential home.
It will be covered by 1 1/2" of gypcrete.
I remember reading about a company a few years ago on this site, but I can't remember what the brand was.
Paul
Paul
Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-0593
NYC LMP: 1307
O:212-505-1837
M:917-939-0593
might as well
just use rigid foam for that.
could use "the barrier" if you want, it's the only thing thin that is also still foam.
do not use reflective insulation.
also it's more typical to insulate the joist cavity, if you can. saves height.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0
- 119 Geothermal
- 394 Solar
