Expansion tank in attic
MikeF
Member Posts: 2
New homeowner (almost) - close next week - trying to understand system in place. Looks like 2 pipe steam radiators but I just got thrown off finding an appox. 15 gal. expansion tank in the attic. What is an expansion tank doing in the attic and is this steam or hot water?
Please remove the blinders from in front of my eyes.
Much appreciation,
Mike
Much appreciation,
Mike
Gravity hot water system
If you have an expansion tank in the attic, it appears that you have a gravity circulation hot water system. These were popular before the 1930's and used the differences in density of heated water to produce circulation in the system instead of an electrical pump.
What does the boiler look like in the basement? Are there large diameter iron pipes directly connected to the top and bottom of the boiler or has a pump been added to convert the system to forced circulation?0
- 129 Chimneys & Flues
- 122 Geothermal
