How to attach hardwood to concrete?
Kevin O. Pulver_2
Member Posts: 87
Future basement floor will have wide plank hardwood flooring.
We plan to have tubing in the floor. If we glued 3/4" OSB to the concrete and then attached the hardwood to that, do you see any trouble heating through all that wood, or do you know a better way? Thanks, Kevin
put radiant in the walls instead
also they have pre made products that have plastic on the bottom and osb on top to keep the wood of the concrete. OSB on cement will not be stable for holding down wood flooring and will not last long due to rot from the dampness.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
