owner
nycbricks
Member Posts: 7
My steam oil fired boiler for a 10 family building is making heat when the boiler control is on summer i do not think it is the aquastate any comments?It sends heat to the first and some of the second floor apartments of the 4 storey building
alot more info needed
there's alot more info needed to give you any reasonable assistance .. and any photos you can include of the boiler system would be wonderful as well.
what type of boiler is it?
what temp is the aquastat set to?
what is the connected EDR load and boiler steam rating?
what kind of burner are you running?
what does your near boiler piping look like?
what is your water quality?
where is the water level in your glass gauge?
what are your pressure settings?
is this a tankless coils system or indirect system?
how long is the boiler running before sending steam upstairs?
answering these questions would give folks here an opportunity to ponder your problem...i'm probably leaving a few things out or have asked irrelevant things, but it's a start to get an idea of your setup.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Heat Timer
Is there a Heat Timer on the job ?There was an error rendering this rich post.
nycbricks
yes0 -
nycbricks
yes0
- 120 Geothermal
- 394 Solar
