noisy air valves on steam system
markcooper
Member Posts: 1
I have 2 steam radiators (far from boiler) that were making hissing noise from air valve, i pitched the radiators correctly, loosened the nut to take out any extra water from the radiators and replaced the air valves with hoffman #40 and the hissing got better but it still makes noise. any answers?
well sounds like.....
that there is not enough main venting on the lines in the basement.....Do you have any OR are they undersized or plugged? How big are these rads?
Whats the system pressure? kpc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
