Hot Attic = Hot Water?
Homestar Plumber
in Solar
What is the best way to use my hot attic to provide me with a hot shower? I've thought of using an indirect water heater heated ONLY with the attic heat , but I am worried about legionellae bacteria as the water will never really be that hot and certainly not for a sustained period of time.
RISA= Roof Integrated Solar Absorber
Hot attics can be water heaters, the jury is out if they are cost effective.
Attached is a good report.There was an error rendering this rich post.
Solar Attic
I've seen this product advertized before. No reason you couldn't build one to do DHW, and ventilate the attic.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Great Find, Rod
No doubt hot attics are a problem, and this is a very simple way to cool the attic and heat some water.
I would think that any hydronic unit heater or fan coil would work. A solar-type differential control with a tight delta T could be the controller.
One issue is that in cold climates, most attics are vented and might freeze. The solution is drainback of course, so the device must be designed to empty completely.
I think drainback helps solve the legionella problem as well, because you don't have the potential for long loops of stagnant water. All the water drains back to the preheat tank. From there it goes to the backup water heater, which will top off the temperature, and kill the bacteria.There was an error rendering this rich post.
and a condensate pan
to drain any sweat from cold water hitting a hot coil. I think a Modine or any hydronic unit heater would work.
It seems a lot simpler than tubing the roof, plus the air moving feature.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
