Manifold Orientation
Kungur
Member Posts: 49
In all the pics I see of manifolds they are installed with the pex connections on the bottom. aS I get ready to do the 1st. floor from the basement the pex will be coming down from above. So can manifold be installed with the connection on top? I want to make as neat an install as possible.
It depends....
Some manifolds come with a flow meter, and if installed upside down, may not read accurately. If that is not a problem, then you have no concerns.
ME0 -
Thanks for your reply!0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
