Yellow
Paul S_3
Member Posts: 1,297
in Oil Heating
What would cause a yellow smoke when you take a smoke test?and what exactly is it?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Air
Yellow smoke is usually caused by too much air0 -
yellow
Or could also could be condensation.0 -
Probably unburned fuel
too much excess air or the wrong nozzle pattern are two of the usual culprits.
What boiler and burner are involved here? What nozzle are you using? What type of test equipment are you using?Baltimore, MD, USA
Consulting0 -
Just making a bet
I would say leak but I just happened to come across this this winter a couple of times.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 125 Chimneys & Flues
- 19 Recall Announcements
