Efficiency: Combi Core Vs. Boiler and DHW storage tank?
james barnett
Member Posts: 8
I'm building a small house in Seattle. The hydronic heating shop looked at the plans and sized the system, and says I can either use a combi core or boiler and dhw storage tank. He's pushing the boiler/dhw tank. Which system will use less energy? To me, it seems the combi core would be more efficient, as the domestic hot water doesn't have to travel a few feet and sit in its own little tank, cooling down all the while. I know for sure which one will cost more: the boiler. And another thing, how come in Seattle I have to add an external low water shut off switch when there's already one installed in the boiler?
On my way out the door I saw a wall-hung combination boiler and on demand hot water heater. Seemed pretty great to me. Anyone know about these things? I'm guessing you don't put them in mansions in Miinnesota, but for a small Seattle house?
OK, enough questions for now.
James Barnett
James Barnett
Selection
The boiler is more expensive until you figure the replacement cost of the CombiCor boiler. All the ones I (and many others) installed fail at the heat exchanger within the first few years. I'll be in San Francisco next week to replace one with a regular water heater and an external heat exchanger (Taco X-Pump Block).
I've had very good luck with the Triangle Tube Excellence combi boiler:
http://www.triangletube.com/TriangleTubeProduct.aspx?CatID=1&PID=19
And talk to Paul Pollets; he's in the Seattle area and know his stuff.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 734 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
