How do I bleed if fast fill is broken?
Joseph_4
Joseph_4 Member Posts: 320
<span>Can someone help me.  If the fast fill doesn't work. will the air be able to get pushed out of a zone? I came up with an idea because fast fill seems to be broken. Instead of opening hose bib all the way, to open only slighty. Because what seems to be happening when I open on full, is the feeder can't keep up with what's going out and the air isn't leaving or maybe I'm letting in new air?</span>
  • bob_46
    bob_46 Member Posts: 813
    Fill
    Fill it with a hose. Watch the pressure so you don't pop the relief.
  • Techman
    Techman Member Posts: 2,143
    Fast fill
    I agree ,hook up a hose to the boiler drain vale and let her rip ,under 30 psi that is
  • Big Ed_4
    Big Ed_4 Member Posts: 3,553
    Agree in a fix
    Connect a double female hose from a domestic water drain cock to the boiler drain to bypass pressure reducing valve .... But if it was my system , I would replace the valve with new ... Less headaches if you do it right I found ....
