gravity hot water system
Joseph_4
Does anyone know what the gravity hot water heating system is all about?someone called me to get rid of the old boiler . I already installed a hot heating system with a pump- size of supply pipe 31/2"large- return pipe 3" size. can someone explain how the system works- there is a new b&g100 pump could this pump work with the new system? could I reduce the size of the pipe from 31/2" to 31/4". the customer only wants to change the boiler and not all the pipes in the house
They do not make 3 1/4"
Do you mean 3"?Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 133 Chimneys & Flues
