Does pipe insulation qualify for tax credit?
Nelson_4
Member Posts: 38
Hi,
I covered my steam pipes in the basement in 1" fiberglass insulation last Fall. Could this qualify for the insulation tax credit?
The 5695 instructions read:<span><span>
Enter the amounts you paid for any insulation material or
system (including any vapor retarder or seal to limit infiltration) that is
specifically and primarily designed to reduce the heat loss or gain of
your home when installed in or on such home and may be taken into
account in determining whether the building thermal envelope
requirements established by the IECC are satisfied.
For property placed in service after February 17, 2009, the property
must be specifically and primarily designed to reduce the heat loss or
gain of your home when installed on or in such home and must also
meet the prescriptive criteria established by the 2009 IECC as in effect
(with supplements) on February 17, 2009. However, if you purchased
property before June 1, 2009, you can still take the credit if you relied on
the manufacturer's certification issued before February 18, 2009, that
the property met the standards in effect before February 18, 2009.</span></span><span><span>
A component is not specifically and primarily designed to
reduce the heat loss or gain of your home if it provides
structural support or a finished surface (such as drywall or
siding) or its principal purpose is to serve any function
unrelated to the reduction of heat loss or gain.</span></span>
here
http://www.irs.gov/pub/irs-news/n-09-53.pdf
so- any insulation that is specifically designed to reduce heat gain or loss of a dwelling unit can get the credit.
I think insulating steam pipes counts, but DHW pipes may not. Could be wrong though.
Either way, I took the credit even for a few cans of 'Great Stuff' foam.There was an error rendering this rich post.
- 129 Chimneys & Flues
- 122 Geothermal
