tankless install
Timco
Timco Member Posts: 3,040
Can you tell me what was wrong with this wiring job? It was totally behind drywall...gas valve, cleaning stations, T&P, and all...
Tim
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Wrong Section......
    I think that belongs down in  the Heating Hell area!   Nice work. How did you find it?
    ("I don't know where the hot water comes from?")
  • Timco
    find
    I found this when I opened up the wall because I could not find the gas valve, or any other parts associated with the heater because it was all walled in. 400 ppm+ CO to begin with, about 70 ppm now with outside air piped in. The vent termination was turned on it's side even though it had a flap that was stuck mostly closed because it was meant to aim down. Bad install all the way around.
    Tim
