Hydronic Sidestream filters? & Dirt seperation/removal
SpeyFitter
Member Posts: 422
Anyone know of any manufacturers or do you install sidestream filters or other forms of dirt removal in your systems (or offer customers the option to?). I just did a search. I've installed one before, it was a nickel bronze one with a S/S flow indicator but I'm sure it's really pricey. I noticed Heatlink makes one out of polypropolene with a cleanable filter. Also, anyone in here use a Spirotrap, or do you at least install strainers?
filter
I have had good luck with the type that looks like a pot-feeder,(canister) from mcmaster carr.it has a metal strainer,that a 'sock'filter fits over.they are very low tech,but I have used them a few places,with good luck.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
