Therms
AHerra
Member Posts: 15
I was wondering if there is a formula or way to calculate how many therms of gas a 1200 sq ft house would use to maintain a 55 degree temperature. House is tight construction with double pane windows. Lots of sun exposure.
Formula
Around here (SF Bay Area) the heat loss for a tight house is around 17 BTU/sq. ft. So:
1,200 sq. ft. x 17 BTU/sq. ft. = 20,400 BTU/hr.
1 Therm = 100,000 BTU
20,400 BTU divided by 100,000 BTU = .20 Therms per hour
Of course, this is an approximation and the 17 BTU/sq.ft. heat loss is typical for a house being heated to 68°; at 55°, you will use much less fuel. For a more accurate calculation, you will need a heat loss survey for your particular house at design conditions.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 129 Chimneys & Flues
- 122 Geothermal
