on demand gas water heater with integral tank?
Royboy
Member Posts: 223
can anyone steer me towards an available on-demand gas water heater with a small integral storage tank as part of the unit? I have a client who says they have heard such a thing exists, and I'd like to look into it as a way to get them around the minimum flow rate issue with the "average" gas on-demand.
extra points for a report on experience with such a unit, as installer or user ... ;-)
thanks - Roy
thanks - Roy
Navien
i believe navien has a on demand with a intergral tankR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
thanks, guys
ended up convincing the client that the best option was an indirect off their WeilMcLain GV boiler. but while looking into this got more edified on the whole realm of pros/cons/etcs re tankless units. that was helpful. always more to know to make good choices ... ;-)
Roy0 -
and, for what its worth
another new thing I learned about in the process is an on-demand recirc unit - that is a hot water recirc unit that only functions when you push a button to activate it prior to, for instance, taking a shower in a bathroom far from the water heater
like all recircs, it doesn't save energy particularly, but does save water and shortens the wait for usable hot water.
unlike other recircs, though, it doesn't waste a lot of energy in the process by continually moving hot water around in a bunch of usually uninsulated pipes. I think I'd go for this as a first option in a situation where hot water sooner is the request
http://www.gothotwater.com/D%27MAND/default.asp0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
