Need info on Mod Con systems.
Harvey Ramer
Member Posts: 2,289
I understand the concept of using TRV's and Alpha or Wilo circs but I am unsure of how to control the heat source with this setup. I am currently designing a Radiant System in a house built with ICF walls and needless to say the homeowners want their Radiant System as green as their walls. The heat source will either be GeoThermo or the all new Altherma air source heat pump. They are also toying with the idea of adding some solar to bring the domestic hot water up to temp. At any rate, we will be heating domestic water, running Radiant and also supplying AC. Any input is appreciated. I have never ventured outside of the 24V control systems.
Harvey
Harvey
- 120 Geothermal
- 394 Solar
