Insulate the pipes for less?
Marcus Mead_4
Member Posts: 53
Just finished a 30' 1.5" main under an unheated crawl space with a 30' 1" dry return.
The last time I needed to insulate pipes, I used Knauf Fiberglass insulation, it snaps on, 1" thick fiberglass, and there is even a peel off adhesive strip to make sure it stays.
Problem is, I can't get it locally, and the closest place is going to cost about $400 for the insulation and shipping.
I know this is probably the most ignorant question imaginable.... But it's in a crawl space, I'll never have to see it again... Couldn't I just use R-13 wall insulation and wrap that around the pipe? Sew it shut with some wire or clips? Is there ANY less expensive option?
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 977 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
